Front diff question
Old Apr 9, 2009 | 05:12 AM
83dodgeswb4x4's Avatar
83dodgeswb4x4
On one of the bolts on either front or rear dif there should be a tag that will tell you what gearing you have. I have noticed that Dodge seemed to favor 3.54 gearing in the halves.
Old Apr 9, 2009 | 08:21 AM
Mad Mudder's Avatar
Mad Mudder
That good info, but there is no tag on front or rear.
Old Apr 10, 2009 | 07:39 AM
83dodgeswb4x4
The best way would be to yank a cover and count the teeth of both the ring and pinion and divide.
Old Apr 13, 2009 | 07:14 AM
Mad Mudder's Avatar
Mad Mudder
I will try that this week and hope I can find some beefy gears too.
Old Apr 13, 2009 | 07:11 PM
83dodgeswb4x4
I did a little checking and Richmond gears offers both a 4.10 ad a 4.56 in both the dana 60 as well as the 9.25. however if you swab to a 60 in the rear as well you can drop that even farther down to a 4.88 or 5.13 or even to a 5.38 which would be sweet if you wish to run a rock crawler. However for the most part unless you plan on doing some major off roading I believe the 4.10 or the 4.56 would be a good choice.
Old Apr 13, 2009 | 11:33 PM
Mad Mudder's Avatar
Mad Mudder
Wink
Im thinking more on 4.56 on front and rear.
Old Apr 14, 2009 | 09:34 PM
rtaylor's Avatar
rtaylor
Default axles
I swapped 60s under my 1/2 ton a long time ago and you can get 15" rims to fit 8 lugs if you can find them, the only thing you will have to do is grind the crap out of the caliper to get the rims to clear I know because thats what I had to do. Most 3/4 tons came with what was called a 44hd which only means heavy duty because its 8 lug, the 60 will bolt right in but you have to have the spring plates from the truck it came out of or a set from a dana 60 or it will not bolt in. The dimensions are the same no difference unless the 60 came out of a Chevy with those the spring perches are a little off, I know of guys that have forced the spring over to mount up on a Chevy 60 and that's too tight for me. I live in Statesville and see your in Mocksville?? Have to get together sometime and talk Dodges..............
Old Apr 14, 2009 | 11:26 PM
Mad Mudder's Avatar
Mad Mudder
That sounds cool. Any mudding places around?
Old Apr 16, 2009 | 09:47 PM
rtaylor's Avatar
rtaylor
The only places I have heard of is Uharrie (spelling) and Brown Mountain. I know there are places over towards the NC Tenn line like Tellico but none here in Statesville...
Old Apr 16, 2009 | 10:46 PM
Mad Mudder's Avatar
Mad Mudder
Is there any 4x4 shops around for the old school Rams?
