Stalling when braking
Old Apr 5, 2009 | 09:56 AM
ssloco2001's Avatar
ssloco2001
Default Stalling when braking
I have a 1983 d150 that stalls when braking. Why?
Old Apr 5, 2009 | 09:27 PM
moparborn's Avatar
moparborn
Does it stall if idling in neutral and you hit the brake?
In drive?
Moving or stopped?
Old Apr 6, 2009 | 08:07 AM
ssloco2001's Avatar
ssloco2001
stalls when moving and coming to a stop .
Old Apr 6, 2009 | 10:13 PM
moparborn's Avatar
moparborn
Check for a vacuum in the brake booster hose,fitting and booster itself or any other vacuum line.
Old Apr 7, 2009 | 08:09 AM
ssloco2001's Avatar
ssloco2001
i checked brake booster and replaced check valve. have checked vacuum too. carb is new but is missing port on front for charcoal canister so didnt hook that up. that wouldnt make it stall though would it? was wondering if distributer would do this if it was going bad . maybe timing advance? any ideas at all
Old Apr 8, 2009 | 09:46 AM
SEAL's Avatar
SEAL
Since you have a charcoal canister I have to ask if you have an EGR valve as this is a classic symptom of its malfunction.
Old Apr 8, 2009 | 08:56 PM
nemesis_SS's Avatar
nemesis_SS
oh yea. car slows down, engine slows down, EGR still dumping in exhaust, engine chokes out. pretty simple, never woulda thought of it
Old Apr 10, 2009 | 08:10 AM
ssloco2001's Avatar
ssloco2001
yes i have egr valve. i will check this out. thanks
Old Apr 12, 2009 | 12:15 PM
ssloco2001's Avatar
ssloco2001
changed egr same thing. could the float be set wrong?
