la/magnum swap
Old Jan 22, 2010 | 11:10 AM
  #21
MrCadillac's Avatar
MrCadillac
Originally Posted by Weltall
Seriously, whatever happened to O2 sensor simulators? Did the EPA outlaw them?
You can still get them for the 96 Chevy Caprices. So I don't think they have been outlawed. But can't you turn that CEL off inside the PCM?
Old Jan 22, 2010 | 11:13 AM
  #22
MrCadillac's Avatar
MrCadillac
Originally Posted by Slomojo
the thing is that the magnum from a 94-01 dodge is full of electronics, so you may have to pull some of the old stuff off of your old block to put onto your new one to get everything working properly. mainly its gonna be replacing the fuel injection stuff with your old carbureted stuff.
That seems to defeat the purpose of doing the engine sway. Electronics are a GOOD thing. I don't know why anyone would want to go back to a carb... Unless you don't take the time to understand the FI stuff.
Old Jan 23, 2010 | 09:40 AM
  #23
ol'dodge4x4's Avatar
ol'dodge4x4
dont forget. mopar performance has a "retrofit" wiring harness for magnum engines. It was developed with mopar action magazine. Stock LA exhaust manifolds will work but use the one without an egr port. Or use the 92 -93 truck manifolds. going to a carb, use an eddy manifold designed for magnums. -
