1991 w150 loss of oil pressure
Old May 11, 2009 | 10:52 PM
150Dodge's Avatar
150Dodge
Default 1991 w150 loss of oil pressure
just noticed today i have almost no oil pressure, prolly happened a bit ago, have been paying more attention to coolant gauge because that was my problem but i fixed that now my oil is the problem, i also noticed that about 2-3 weeks ago it started smoking on some of the startups not all, then it would stop after a puff of smoke, i would assume its oil, any ideas, thanks
Old May 12, 2009 | 06:23 AM
83dodgeswb4x4's Avatar
83dodgeswb4x4
The puff of smoke on start up could be from worn valve guides. Does it puff each time you start it, or only if it has set for a while? As for the low oil pressure, you could have a sending unit going bad which is giving a false reading. Personally I run a mechanical gauge just because of that. You might consider getting an inexpensive mechanical gauge and hooking it up just to check the pressure.
Old May 13, 2009 | 12:23 PM
150Dodge's Avatar
150Dodge
yeah thats what my next step is, to put a mechanical guage on it, the manual i have said it is next to distributer, is that where i should put it on
Old May 13, 2009 | 07:21 PM
charlie1935's Avatar
charlie1935
Yep, on the passanger side of the dist.
All the way back.
