changing valve cover gaskets
Old May 24, 2009 | 01:45 PM
tooltime's Avatar
tooltime
Default changing valve cover gaskets
it is a 86 318 and i want to/need to change the gaskets.i cant have it done bc of money right now and i already have the gaskets.is this something i can do myself?i have looked at a repair manual and says it will be about a hour to do and looks easy to do.does anyone have any tips thanks
Old May 24, 2009 | 02:23 PM
nemesis_SS's Avatar
nemesis_SS
https://dodgeforum.com/forum/diy-do-...emesis_ss.html
i cant stress enough how gentle you must be with the AIR pump lines (if you have them). They are in the way of the driver side cover and if you pry on them too much youll brake them right off the manifold (like i did). a bitch to fix.
Old May 24, 2009 | 06:43 PM
Mad Mudder's Avatar
Mad Mudder
Air pump lines? We dont need any stinking air pump lines.....LOL
Old May 24, 2009 | 07:52 PM
tooltime's Avatar
tooltime
just wondering what is theair pump lines?i don't have them on it though.why do you have to take out the spark plugs?.i may not do it seems like more to it than i was thinking
Old May 24, 2009 | 10:14 PM
nemesis_SS's Avatar
nemesis_SS
did i say take out the spark plugs? no its barely any work at all. its like 5 or 6 nuts per side
Old May 24, 2009 | 10:58 PM
moparborn's Avatar
moparborn
5 bolts per side,remove the breather,pcv valve.
The brake booster may make the drivers side cover a little tough to get off but it will come off.
Old May 25, 2009 | 04:55 PM
nemesis_SS's Avatar
nemesis_SS
lol. 5 or 6. nuts or bolts. just the sort of details i get wrong. they go back on with 90 inch-lbs. the brake booster was in the way, but with a little finessing i didnt have to remove it.
as for removing the plugs, what it says is remove the plug WIRES. they get in the way, and also clip onto a bracket which is attached to the passenger side valve cover. you just have to unplug the wires by pulling the boot off the plug. be sure to label them.
dont do it if you arent confident. But if you like to get your hands dirty this is an easy job. just pay attention to what you take off, where it goes, do it slowly, apply the sealant, fit the new gasket, and do it all in reverse, one side at a time.
Old May 25, 2009 | 05:53 PM
tooltime's Avatar
tooltime
it looks like it would be easy,just take the air filter off and the take the overs off.the pass side will be harder bc of the heater hoses.i want to do this myself.i have done plugs before 3 or 4 times and put on a egr valve on my wifes van.about tighting the bolts up also i am not sure about.
Old May 25, 2009 | 08:14 PM
moparborn's Avatar
moparborn
Use good gaskets and some will argue this but do not be afraid to use some permatex and do not over tighten the bolts.
Old May 25, 2009 | 10:46 PM
nemesis_SS's Avatar
nemesis_SS
i second the use of a liquid gasket stuff. the block will be all pitted and that will fill it. and help with adhesion
