lift options
Old Jun 3, 2009 | 02:27 PM
mikey0469's Avatar
mikey0469
Default lift options
i have a 82 w150 stepside 4spd. is anyone on here aware of any lift options, besides skyjacker, with 8 inches of lift? im not sure, but im thinking about going with either 38's or 40's. would 8" be enough?
Old Jun 6, 2009 | 09:09 PM
Mad Mudder's Avatar
Mad Mudder
You will need to beef up or change you Dana 44 to a Dana 60. And try http://www.roughcountry.com/ they have alot of 1st. Gen Rams lifts.
Old Jun 9, 2009 | 07:04 AM
durec's Avatar
durec
Default Lifts & Leveling Follow Up
Fella's, I have an '88 2W . I only want to raise or level the front end.....is that possible without a full body lift?
Thanks
Old Jun 10, 2009 | 07:17 AM
Mad Mudder's Avatar
Mad Mudder
Thanks
You should be able to find something for that at a local parts house.
Old Jun 10, 2009 | 07:59 PM
1952M37's Avatar
1952M37
We lifted a 87 Ramcharger with 8" of lift and are having troubles with the front driveshaft angle ( way too much). Solved the problem with the rear with a special yoke from HIGH ANGLE DRIVELINE AT 530-877-2875 ask for Jessie
They make CV's for rockcrawlers and more
Old Jun 18, 2009 | 01:35 AM
mikey0469's Avatar
mikey0469
so what did you end up doing for the front drive shaft? i was curious that the driveshafts woud be at too much of an angle. ive seen insane lift kits on some trucks but the front driveshaft was removed. haha.
