New to Forum and a Fuel Problem 150 Ram
Old Jun 11, 2009 | 09:32 AM
RoofDawg's Avatar
RoofDawg
Default New to Forum and a Fuel Problem 150 Ram
Hello all, I just purchased a '92 150 Ram with a fuel injected 318 auto (100,000 miles). It ran really well at first and then it started dumping fuel. It looks like it is burning diesel out the exhaust, now. I completely tuned it up cap, wires, rotor, pcv, etc... Still ran terrible replaced the EGR, mass sensor and the one next to it on the throttle body, the TS something sensor can't remeber off hand. At idle in neutral/park it runs like a gem however, get some heat in to it and goes south.
I'm out of ideas, any suggestions?
RD
Old Jun 11, 2009 | 05:36 PM
moparborn's Avatar
moparborn
Any codes?
Any vacuum leaks?
Fuel filter,check fuel pressure.
Next would be o2 sensor.
Old Jun 12, 2009 | 10:27 AM
RoofDawg's Avatar
RoofDawg
Moparborn, Codes pointed to the 2 sensors I mentioned previously and fuel pressure check out. the fuel filter appears newer and no leaks that we can tell. I mean it really runs rough starts caming and lunging. I need to get a manual but is their a fuel pressure sensor up front by the throttle body? RD
Old Jun 12, 2009 | 11:31 AM
SEAL's Avatar
SEAL
Have you looked inside the throttle body when you rev it a little to see the spray pattern of the injectors?
Old Jun 12, 2009 | 12:29 PM
trinity03's Avatar
trinity03
Welcome to the forum... check the fuel filter...
Old Jun 12, 2009 | 06:41 PM
kev2's Avatar
kev2
ideas: easy things first
check the inj harness a grounded wire will dump fuel
the thermostat is there? -195deg.
air filter? clean?
look at FPR (fuep pressure reg) vac line is attached...also thereshould be NO FUEL in vac line if so reg diaphram is bad..
Old Jun 15, 2009 | 08:36 AM
RoofDawg's Avatar
RoofDawg
Pulled a vac on the fuel pressure regulator and appears this may be the answer it wasn't pulling any vac. I'll check the fuel harness for any grounding.
SEAL, what kind of spray pattern should I be looking for?
RD
Old Jun 15, 2009 | 08:45 AM
kev2's Avatar
kev2
fine misting cone pattern...do not want drops dribbles streams and have someone turn off eng- spray should come to zero flow no bleed off trickle off, drips etc
Old Jun 15, 2009 | 10:30 AM
RoofDawg's Avatar
RoofDawg
Thanks kev2 I appreciate the info
Old Jun 17, 2009 | 07:49 AM
RoofDawg's Avatar
RoofDawg
Thumbs up
Well the mystery is solved. It was the temperature sensor up front along with the O2 sensor. My understanding is that it is what controls the fuel for the electronic choke on cold start up it kept sensing that the motor was cold and just kept dumping fuel. Replaced it and it helped alot still ran rough. So, I replaced the O2 sensor. Runs like a charm now.
Gentlemen thanks for the help and input.
I'll be around
RD
