starting problems,'86 Ram
Old Aug 11, 2009 | 04:32 PM
ram150ga's Avatar
ram150ga
Default starting problems,'86 Ram
I have to start my truck by jumping the fender mounted starter relay, I followed Sam ,from Sams garage & Two guys garage advise & replaced the ignition switch & lock assembly, also I have replaced the neutral lockout switch & the starter relay. HELP!!! This old ram now has a 343c.i. roller motor. JHB
Old Aug 11, 2009 | 04:54 PM
kev2's Avatar
kev2
confusion - 343 is an AMC engine that was limited use in some jeeps... SO it is now in your dodge....correct.
did you install this?
It has worked in the past?
this is a ram D150?
the wiring dia tells me .....see if correct
starter relay
yellow wire should be hot when you turn to start?
Brn/yellow is a ground in P/N?
brn is trigger to starter should be hot when starting?
Old Aug 11, 2009 | 07:49 PM
crazzywolfie's Avatar
crazzywolfie
are you sure the engine is a 343 and not a 340
