Stupid transmission problems
Old Aug 15, 2009 | 09:23 PM
rwb's Avatar
rwb
Default Stupid transmission problems
My trans only shifts correctly when I floor it, otherwise it shifts with a violent jerk from 2nd to 3rd. It also holds first gear longer than it should. Any ideas about what it might be?
Old Aug 15, 2009 | 11:45 PM
crazzywolfie's Avatar
crazzywolfie
have you checked the kickdown linkage?
Old Aug 16, 2009 | 08:10 AM
rwb's Avatar
rwb
Yes, everything was fine then all of the sudden it started doing it. I'm now thinking that either it is a solenoid in the tranny or some check ***** are sticking and needing the higher pressure when I floor it to move.
Old Aug 16, 2009 | 11:20 AM
SEAL's Avatar
SEAL
First check your fluid level and condition as this is a symptom of low fluid and is the easiest to check. When was your last fluid and filter change? Late shifts and harsh shifts are often caused by a faulty vacuum diaphragm.
I would try a little K&W trans-x used according to directions and drive it about 100 miles then change the fluid and filter. If that doesn't fix the problem I would let a (GOOD) tranny shop take over.
Old Aug 16, 2009 | 12:36 PM
charlie1935's Avatar
charlie1935
Never heard of a mopar tranny having vacuum controlled operation. I know GM did.
Of course I could be mistaken.
Old Aug 16, 2009 | 01:26 PM
SEAL's Avatar
SEAL
Oops. Got my tranny's crossed. I have a GMC and a Dodge. Governor pressure is controlled by the linkage on the Dodge. Sorry.
Old Aug 16, 2009 | 01:53 PM
rwb's Avatar
rwb
I'll look at the linkage when it dries off outside.
After looking at it, it seems my return spring is weak. Do you think that could be the problem?
