91 dodge d150 coolant leak
Old Aug 24, 2009 | 08:18 PM
Bbuck1123's Avatar
Bbuck1123
Default 91 dodge d150 coolant leak
i have coolant pouring out when i fill up the radiator. I replaced the water outlet thinking that was the problem but it still leaks behind the alternater above the fan and i dont know what it is maybe a blown gasket or blown engine idk please help!!!!
Old Aug 24, 2009 | 08:20 PM
rwb's Avatar
rwb
Check your thermostat gasket. That is right in area you are stating.
Old Aug 24, 2009 | 08:23 PM
Bbuck1123's Avatar
Bbuck1123
if your talking about the gasket under the water outlet i replaced that and the upper radiator house but it seems like the leak is coming from the middle of the engine
Old Aug 24, 2009 | 10:04 PM
crazzywolfie's Avatar
crazzywolfie
is it one of the skinnier lines that run to the heater core? i can't think of anything in the middle of the engine.
