Header Question??
Old Sep 6, 2009 | 08:20 PM
zogg's Avatar
zogg
Default Header Question??
I have an 87 Ram w/318 2wd and found a set of shortie headers for a 95 Ram (used - $25). Is there a difference between my enging and the 95? I thought I read something about the newer engine being a Magnum, and lots of stuff will not interchange...correct??? Thanks
Old Sep 7, 2009 | 09:07 AM
SEAL's Avatar
SEAL
I believe there was a change in the exhaust from pre 93 to post 94. You might measure the bolt holes to see if they match but the head outlets may still be different. Go to a couple of header sites and check but I think you will find a different part number for pre 93 and 95.
