please help!!!
Old Dec 2, 2009 | 12:50 PM
blueram 89's Avatar
blueram 89
Default please help!!!
I have a 1989 dodge ram 50 pick up it has the ungo system in it i think this is causing my truck not to start but i have two wires off from it one looks like a ground and the other has a small blug on it that i think plugs into the box were i do not know if any body can help i be realy gatefull im looking for a wiring diagram or a pic thanks for any help im going nuts Dan the model number is 14500 active stater cut-off
Old Dec 2, 2009 | 04:04 PM
AeSix's Avatar
AeSix
I'm going to be mean for a second, and say simply "PUNCTUATION"
(If you're wondering, there is no period if the end quote is at the end of the sentence.)
Now, To be helpful.
I'm going to try to figure out what you're asking here. You have a device, an active starter cut-off? The device has 2 wires, one you're assuming is ground, and the other you say has a plug?
I'm assuming by the lack of knowledge you're attempting to install this?
Google proved to be useless for finding images, or any real information for this device. There was a forum post in which the author by-passed his though. Perhaps this is something you can do?
If nothing else, hopefully my post was able to clarify what you're wanting so others might be able to help more efficiently.
Old Dec 2, 2009 | 04:51 PM
crazzywolfie's Avatar
crazzywolfie
are you sure the model number is 14500. try looking here. http://www.clarion.com/jsp/search/Pr...us&language=en
Old Dec 3, 2009 | 12:08 PM
blueram 89's Avatar
blueram 89
well thank you for the puncuation correction . The system is installed already. The problem is the one wire looks like a ground and the other wire has a small plug on the end. Im not sure were these wires go. I'm lookink for a wiring diagram or a picture of how its installed. I checked the number on the box and it say's 14500 model # Thank you for any help ,Dan
Old Dec 3, 2009 | 08:07 PM
aaron7's Avatar
aaron7
Why not just yank it all out? Not like it's doing any good anyways.
Old Dec 4, 2009 | 11:30 AM
blueram 89's Avatar
blueram 89
Thanks aaron7. I think thats what im going to do all together your right its not doing any good any way. But thanks for all the help, Dan
