timing help...
Old Dec 11, 2009 | 01:04 PM
85bluecrew's Avatar
85bluecrew
Default timing help...
I just installed a used / rebuilt motor into my truck and when I am trying to start the truck it ran for a little bit and then died. Now when I try to restart it, it backfirs thru the carb. I need to check the distributor and see if it is lined up correct. What position does the rotor need to be facing when at TDC? I can not find my book now that I have moved, it is burried in the garage.
Old Dec 11, 2009 | 02:09 PM
SEAL's Avatar
SEAL
At true TDC the rotor will point to #1 wire. Drivers side front cylinder.
Old Dec 11, 2009 | 02:30 PM
crazzywolfie's Avatar
crazzywolfie
dont forget that your cam turns twice for every 1 rotation of your crank so it could look like it's 180* off but it's not
Old Dec 11, 2009 | 03:16 PM
85bluecrew's Avatar
85bluecrew
Thanks for the info. I just thought it was weird cause it was running just running rough and now coughs up thru carb. I will doule check the location of the rotor, I believe it was pointing towards the passenger side the other day....I will get it lined up. Thanks again for the feedback.
Old Dec 11, 2009 | 05:14 PM
crazzywolfie
if it is coughing through the carb while your trying to start the truck you most likely have the distributor 180* off. it does not hurt to try rotate it 180*. if it don't fire up you could always rotate it back.
Old Dec 13, 2009 | 10:02 AM
85bluecrew's Avatar
85bluecrew
Thanks, I flip it 180 an it fired right up. I should have done that a couple weeks ago. This motor sounds frickin awesome.
