1989 Dodge Ram 1500 - Won't Start!!
Old Dec 18, 2009 | 11:27 AM
dreamer1uk's Avatar
dreamer1uk
Hi,
How did you check for Spark?
If your not getting spark from the coil, you can check those easy with an ohm meter, checking the primary and secondry windings. If the coil check out good, you need to trace the ignition circuit further back, such as looking at the ballast resistor, starter relay wiring and the distributer pickup
