transmission pan gasket/filter...torque specs?
Old Feb 2, 2010 | 08:57 PM
chris015's Avatar
chris015
Default transmission pan gasket/filter...torque specs?
not sure if its the 904 or 727. Whats the torque on the rubber gasket? and the filter is bolted on with 1 bolt correct?
also with it being a 78 do i need to use the atf+4 or can i go with the cheap stuff?
Old Feb 3, 2010 | 08:05 AM
SEAL's Avatar
SEAL
Dexron 2 or better is recommended. Pan bolt torque is 96 in-lbs. My 727 has 3 bolts for the filter.
