Coolant leak
Old Feb 27, 2010 | 06:48 PM
RamKing's Avatar
RamKing
Default Coolant leak
Hey
i have a coolant leak thats coming inside my cab from the black air box(dont know the name) i was wondering how i take it out, i took out the screws form the top through the glove box but wont come out(third and fourth pics) my haynes repair doesnt have any thing on it any help would be awesome.
thanks
Old Feb 27, 2010 | 06:50 PM
crazzywolfie's Avatar
crazzywolfie
looks like your heater core is leaking.
Old Feb 27, 2010 | 06:55 PM
RamKing's Avatar
RamKing
do u know to take that black box off?
Old Feb 27, 2010 | 07:01 PM
crazzywolfie
i am think you have to take the whole dash out.
Fig. 17 Heater assembly. Ramcharger, Trail Duster & Conventional Cabs less A/C. 1981-84 shown, 1985-87 similar
1981-87 Models
  1. Disconnect battery ground cable.
  2. Disconnect heater hoses on engine side and plug heater outlets.
  3. Remove right side cowl trim if so equipped.
  4. Remove glove box, then structural brace through glove box opening.
  5. Remove right half of instrument panel lower reinforcement, making sure to disconnect ground strap.
  6. Disconnect control cables, then blower motor wires on engine side.
  7. Disconnect wires from resistor block.
  8. Remove screw holding heater to cowl side sheet metal.
  9. Remove 6 heater retaining nuts on firewall, then remove heater.
  10. Remove mode door crank and 15 screws to remove cover from housing, then slide heater core out.
  11. Reverse procedure to install.
Old Feb 27, 2010 | 07:09 PM
RamKing's Avatar
RamKing
thanks , i was hoping i didnt have to take out the dash, dammint
where did ui get the pic form what book?
Old Feb 27, 2010 | 07:51 PM
crazzywolfie
i got the pic from alldata.
Old Feb 28, 2010 | 07:06 AM
SEAL's Avatar
SEAL
I also am going to have to replace my heater core so I sympathize with you. I am getting a fogged up front window when I turn on the defrosters and that fragrant aroma of antifreeze. The leak is still small enough not to be dumping fluid inside the truck. Good luck.
Old Feb 28, 2010 | 12:42 PM
tooltime's Avatar
tooltime
I had a leak also but it was the hose
Old Feb 28, 2010 | 07:25 PM
RamKing's Avatar
RamKing
can u share some more?
Old Feb 28, 2010 | 08:27 PM
crazzywolfie
what more do you want?
