Project: Black Rambo
Old Mar 20, 2010 | 10:11 PM
Halmotors's Avatar
Halmotors
Oh, I didn't put things on the list in any particular order of being done. First and foremost for me is putting the wiring harness in. I yanked it out today so I could start fresh, so we'll go from there. I'll probably do a compression test to see how the rings and valve seals are doing.
The radiator and tranny cooler are seriously shot. The radiator has mouse turds in it. The PO owned a junk yard, so I'm sure he scrounged parts where he could. Hoses are pretty brittle and junk. Engine mounts are torn up. Lenses are broken. Transmission probably does need a slight adjustment.
A lot of little things that add up, for sure.
Old Mar 20, 2010 | 10:27 PM
crazzywolfie's Avatar
crazzywolfie
i would not be too worried about the radiator and cooler unless they leaked. the wiring harness looks like it needs alot off work. it looks like a completely custom wiring job. i would be more conserned on getting it up and moving then get all the small stuff like lenses and engine mounts.
Old Mar 21, 2010 | 07:34 PM
Halmotors's Avatar
Halmotors
The primary goal right now is the wiring harness. It's a Painless wiring harness, so it shouldn't be too difficult to do. It's just a matter of taking the time to do it properly.
