vacuum problem
Old May 15, 2010 | 11:43 AM
nathan5603's Avatar
nathan5603
Default vacuum problem
My 1982 RAM with the 3.7L 1bl carb is losing vacuum and I don't know where. It's making noises at the back of the engine when I shut it off, but I am unable to locate it. Do these trucks have ported or manifold vacuum?
Old May 15, 2010 | 07:12 PM
SEAL's Avatar
SEAL
With the engine idling use a spray can of carb cleaner and spray it at any place there might be a leak. If the engine accelerates you have found the leak.
Old May 16, 2010 | 04:26 PM
TennMopar's Avatar
TennMopar
Not positive on the carbed engines but TBI use manifold vacuum. If the carb spray trick doesn't work, hook up a smoke machine to a vacuum line.
Old May 16, 2010 | 06:26 PM
SEAL's Avatar
SEAL
Not positive on the carb either but TBI has both.
