3.9 engine swap
Hello I was wondering if a 318 would bolt up to the tranny in my truck I have a 1989 dodge w100 with the 3.9 v6 oh and it has a 4 speed tranny. any insight would be appreciated thanks.
is it an automatic? a 318 should bolt up to the trannny if it is an automatic but a 318 will not just bolt into your truck. you need a motor mount extension for the one side.
no it has a 4 speed manual, and is there a place to get the motor mount extention?
i don't know if there is a place to get a motor mount extention. i had mine made for my truck. i don't know if the fly wheel and clutch would be the same for the 318. i think the tranny should bolt up to the 318.
If the automatic will bolt up that mens both engines have the same mounting configuration which means the the 4 speed bell housing will also fit both. You should check with the parts house about the size clutch and flywheel for each to see if they are the same. I would think they are not.
