89 dodge snow commandor
Ok i have a 89 1 ton 4x4 with the 360 and it is the tbi. Ok i am having problems with it running it will start and the injectors spray to start the truck then they stop working and the truck stalls. We know it is not the ecu ibought a new one and tested that and still same thing and have good grounds, it is loseing ground when truck starts and cancels the injector fire.
Any one ever have any thing like this?
All and any help will be great.
Thank you
Tony
Thank you
Tony
Have you pulled the codes? You may be having a problem with the ASD relay. You might also try a temporary ground from the throttle body to the battery ground to eliminate any grounding issues as a problem.
ASD=automatic shutdown relay. You have onboard diagnostics and here is how you pull the codes in your truck.
ON-BOARD DIAGNOSTICS Dodge OBD1 Pre 96
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
51 Fuel system lean
52 Fuel system rich
The ASD is on the inside drivers fender just under the hood spring. There will be 2 to 4 relays there depending on equipment in the truck. The ASD should be the second from the front of the truck.
