85 d150 headlight problems
Old Aug 30, 2010 | 12:47 AM
dodgeram150's Avatar
dodgeram150
Default 85 d150 headlight problems
well i already replaced my headlights 2 months ago and i checked all of the fuses theat were there and they were all good and i went through some of the wireing and redid the ones that looked saspicious but on the dimmer switch the wires were pluged in on the top of it and a wire on the side was attached but the one on the bottom had nothing on it but also there were no scratches to say something was there but the turn signal lights come on when i pull the switch to turn on the lights and the dash lights work as well i was hoping that someone could help me eliminate some of the choices left
Old Aug 30, 2010 | 01:10 AM
crazzywolfie's Avatar
crazzywolfie
what exactly is the problem? the front lights are not working? the turn signals and marker lights share the same light bulb so when you turn the lights on they should be on unless you mean that they are flashing which they should not be doing.
Old Aug 30, 2010 | 02:10 AM
dodgeram150
no the turn signal and marker lights work its the headlights that dont work.
Old Aug 30, 2010 | 06:53 AM
SEAL's Avatar
SEAL
The dimmer switch should have a 16 gauge red/white wire (to the headlights) & an 18 gauge red/white wire (to the dash panel connecter) both on one terminal, a 16 gauge yellow wire in the middle (to the headlight switch), and a 16 gauge black wire ( to the headlights) on the third terminal.
Old Sep 1, 2010 | 02:28 PM
dodgeram150
alright its all fixed the connectors to the dimmer switch were getting bad connection thanks for all of your help
