Lift
Old Sep 20, 2010 | 10:07 PM
redsnook1125's Avatar
redsnook1125
Default Lift
My 90 W150 sits nose down a little, i want to lift the front end with 2 inch blocks. Has anyone done this? Does anyone know if you need slant blocks or straight blocks?
Old Sep 21, 2010 | 06:55 AM
Ironmower's Avatar
Ironmower
I've seen blocks up front, but wouldn't recommend it. I added two plies on each side of my w250 and gained just about an inch and a half. I've seen blocks come loose, when wheelin hard.
If you go with the blocks or leafs you can get tappered shims, to get your pinion angle corrected.
