Washer pump?
Old Oct 14, 2010 | 03:04 PM
pickfiddle's Avatar
pickfiddle
Default Washer pump?
So my windshield washer pump hasn't been working. I took it off and cleaned the connector and put power directly to it just to make sure it was burnt out. It runs fine. I hooked up a meter to the connector on the harness and found I'm not getting any power when I push my little button. My question is this. Is it easier to just run a new wire to a toggle on the dash or to fix the switch on the lever of the steering column? It's an 89 d100 5.2L
Old Oct 14, 2010 | 03:53 PM
SEAL's Avatar
SEAL
Have you checked the #6 20 amp fuse?
Old Oct 14, 2010 | 05:26 PM
pickfiddle's Avatar
pickfiddle
I just changed all my fuses and relays on monday
Old Oct 14, 2010 | 05:48 PM
SEAL's Avatar
SEAL
Do you have power at fuse #6?
Old Oct 14, 2010 | 06:49 PM
pickfiddle's Avatar
pickfiddle
as far as I know yes, but its raining too hard to go out and check right now.
to replace the switch, would I have to remove the whole column, or can it be done on the truck?
Old Oct 15, 2010 | 05:07 AM
SEAL's Avatar
SEAL
It can be done on the truck. You must remove the steering wheel to remove the switch.
