1985 dodge ram w150 dually
Old Oct 17, 2010 | 01:04 AM
dodge2500hemi4x4's Avatar
dodge2500hemi4x4
Cool 1985 dodge ram w150 dually
im a little need to this form but i could use a little help I have a 1974 dodge motor home and i want to put the rear end under my 1985 w150 can any tell me if this is possable with little modification also the max tire size that will fit it im building a mud truck out of the 85 and this motor home is just stting here so i thought it would look sweet with a dually
under it
any help is greatful
thanks
Old Oct 17, 2010 | 01:16 AM
crazzywolfie's Avatar
crazzywolfie
i don't think you would be able to use the dually axle. the rear axles would need to have the same gears as the front axle.
Old Oct 17, 2010 | 02:14 AM
dodge2500hemi4x4
Can't I just change the gear ratio
Old Oct 17, 2010 | 02:16 AM
dodge2500hemi4x4
also I'm changing the front 4 wheel drive to 3/4 ton prob should have said that befor
