Idle.
Old Oct 30, 2010 | 01:03 PM
Dodge_Ram_3500's Avatar
Dodge_Ram_3500
Default Idle.
Hey guys, wondering what your trucks rev at idle? My truck used to rev at around 1000-1500, but when a guy was looking at my trucks motor for reference to his motor he was rebuilding, he plugged in a connector, and my truck started reving really slowly, it revs around 500 now, which is great on gas, but its really tricky driving it for the purpose of offroading, it stalls quite often, even at idle its fighting to stay alive. The problem is, I cant find the plug he plugged back in, any ideas? LOL, thanks again fellas!
Old Oct 30, 2010 | 01:31 PM
crazzywolfie's Avatar
crazzywolfie
have you check the timing. the truck should idle at about 750rpm. if you adjust the timing a little bit you should be able to get it up to 750 easily.
Old Oct 30, 2010 | 02:00 PM
SEAL's Avatar
SEAL
Is the ISC (idle speed control) actuator plugged in?
Old Oct 30, 2010 | 02:33 PM
Dodge_Ram_3500
I'll try timing it and see what happens. Which plug is the ISC?
Old Oct 31, 2010 | 08:32 AM
SEAL's Avatar
SEAL
It is the 4 prong plug on drivers side of the throttle body by the accelerator cable. It can also be called the AIS (automatic idle speed) motor. It is the thing that actually physically controls the idle speed of the engine.
Old Oct 31, 2010 | 02:21 PM
89ram150's Avatar
89ram150
My idle speed motor doesn't work so I run a little high without the a/c on, about 800-850. But with the a/c and lights on it idles at 700, 600-650 in gear. I found that if the idle is down too low the a/c clutch will cut out or not come on at all when you turn the a/c on.
Old Oct 31, 2010 | 07:09 PM
Dodge_Ram_3500
That happens to one thats not plugged in, the prongs are corroded a bit so I'll clean it up and plug it back in tommorow morning and see if it works then.
