I KNOW I ASK ALOT! 4X4 recap?
Old Nov 7, 2010 | 06:09 PM
nealwiley's Avatar
nealwiley
Default I KNOW I ASK ALOT! 4X4 recap?
I do have the Spicer front axle, any ideas where the 2 vacuum line go?
Old Nov 7, 2010 | 09:16 PM
SEAL's Avatar
SEAL
Both vacuum lines go to the switch on top of your transfer case.
Old Nov 8, 2010 | 09:17 AM
nealwiley's Avatar
nealwiley
Where does the switch get its vacum?
Old Nov 8, 2010 | 11:59 AM
SEAL's Avatar
SEAL
The switch has 4 vacuum lines. The switch gets its supply vacuum from the round accumulator ball on the inside of the left frame by the transfer case. The accumulator ball gets its vacuum from the throttle body or carb. There is also a vacuum line on the switch that goes up to the right front fender to a filtered vent.
Old Nov 9, 2010 | 08:56 AM
nealwiley's Avatar
nealwiley
Thanks , iwill check it out asap, this time change is killing me!
Old Nov 11, 2010 | 08:14 AM
nealwiley's Avatar
nealwiley
Fixed! Thanks seal!!! Again
