Not starter or battery, confused..
Old Dec 5, 2010 | 10:05 AM
nealwiley's Avatar
nealwiley
Default Not starter or battery, confused..
When starting engine acts as if the battery is weak or the starter is dragging, replaced both starter and battery and still having the same problem,any suggestions.....?
Old Dec 5, 2010 | 10:26 AM
charlie1935's Avatar
charlie1935
Check ALL grounds, batt. to engine, frame and body.
Old Dec 5, 2010 | 12:41 PM
crazzywolfie's Avatar
crazzywolfie
did the place you bought the battery from test or charge it before you bought it. you should also test to make sure you are getting the same voltage at the starter that you have at the battery.
Old Dec 5, 2010 | 01:01 PM
nealwiley's Avatar
nealwiley
BAD GROUND<<<.....THANKS FOLKS!
Old Dec 7, 2010 | 07:56 AM
Ironmower's Avatar
Ironmower
Glad to see you didn't give-up on it.
