Injectors
Old Dec 13, 2010 | 04:19 PM
FourLowNGo's Avatar
FourLowNGo
Question Injectors
So this is a stupid question, BUT how do you replace the injectors on a 318 with TBI?
Old Dec 14, 2010 | 12:26 AM
pickfiddle's Avatar
pickfiddle
With the air cleaner removed you need to relive the fuel pressure. unscrew the torx screw holding the injector clamp. Use a small screwdriver tolift of the top of the injector the pry out the old one from the throttle body. When you put the new ones in grease the new o rings and press the injector into the cap until the top o ring is flush with the bottom of the cap then just press the new injectors into the TB and screw everything back in
Old Dec 14, 2010 | 07:53 PM
FourLowNGo's Avatar
FourLowNGo
Hey thanks, but I already figured it out.
Thanks again though!
Brittany
