gas in the oil
Old Jan 21, 2011 | 04:59 PM
crazzywolfie's Avatar
crazzywolfie
Default gas in the oil
i'm not talking about a small amount of gas in the oil. i would have to say there is about 1-2 liters in the oil. i did an oil change less than 2 weeks ago. i am guessing that the diaphragm in the mechanical fuel pump has a hole in it or something but i was more so wondering if this could have been caused by the return line not being hooked up. i would definitely not want this to happen again if i do replace my fuel pump.
Old Jan 21, 2011 | 05:34 PM
SEAL's Avatar
SEAL
A diaphragm pump is a positive displacement pump and the fuel that is pumped and not used needs to go some place or the system will over pressurize. If it can't return to the tank when proper pressure is reached, as per design, the diaphragm will receive higher than designed pressure and will be prone to premature failure. Usually this problem will give drivability symptoms and/or leaking at the carb.
Old Jan 21, 2011 | 05:49 PM
crazzywolfie
that makes sense. my truck has been having problems and the plugs have been ending up black.
Old Jan 28, 2011 | 08:58 AM
charlie1935's Avatar
charlie1935
Not to be smart assed but what about all the years they did not have return lines?
Old Jan 28, 2011 | 10:39 AM
SEAL's Avatar
SEAL
This has always been true but no one gave it a thought. Someone finally thought about it and decided to add a return line and everyone adopted it. Improvements only come when someone thinks there might be a problem and then finds a solution.
