1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I realize this may be the drain clogged, but has anybody encountered a leaking box itself? Also, is air blowing the water back into the box really an issue? Thanks
In the face of that info it appears that you need to clean the drain tube. On mine you can just pull the fan motor and clean out the box and I think yours is the same.
