Door glass removal
Old Feb 6, 2011 | 09:06 PM
Texas Performance's Avatar
Texas Performance
Default Door glass removal
Does anyone know how to remove the door glass on an 85' 150?
Do I have to remove/drill out the rivets and remove the regulator to get the glass out. I am in the process of restoring a 1985 that I was given, the last items that need to be taken part are the door glass. HELP!
Old Feb 6, 2011 | 10:26 PM
SEAL's Avatar
SEAL
No, you do not have to remove the regulator. Once you remove the vent window and its frame the main window will slide forward enough to slide off the regulator.
Old Feb 7, 2011 | 08:28 AM
Texas Performance
I've tried to get the vent glass out, is there a trick to it? I thought I tried every way to get the vent out.....
Old Feb 7, 2011 | 09:28 AM
SEAL's Avatar
SEAL
There is one screw at the bottom of the track and one screw on the outside front of the door and it comes right out. The main window must be down.
Old Feb 8, 2011 | 08:08 AM
Texas Performance
I have the screws out, I have trieds all different angles and nothing seems to clear. I'll try again this afternoon.
Thanks for your help.
Old Feb 8, 2011 | 11:17 AM
SEAL's Avatar
SEAL
Have you removed the 2 pieces of weather stripping across the door at the bottom of the window opening. This must be done. You might try raising the main window slightly. If you can get the front of the glass out of the vent window channel you can slide it forward to remove it from the back channel and then slide the window rearward to give more clearance for vent assembly removal.
