window parts(inside door) question
Old Mar 13, 2011 | 04:07 PM
tooltime's Avatar
tooltime
Default window parts(inside door) question
I have power windows on the truck and they just open about 2-4 inches. I just sprayed the tracks and the parts with white grease and the drivers side will work but not the pass. My question is what holds the glass to the "X" arms(don't know name). My nissan has a bar going across to hold the window but the Dodge does not on both doors.Where can i get one at if it is missing that and know about the price. The pass side still will not work and that switch was replaced at 1 time and bypass the drivers control. thanks
Old Mar 14, 2011 | 07:26 AM
SEAL's Avatar
SEAL
I am not sure what system is in your truck but dodge used a plastic strip gear system around that year. If you have that system, replacement gear tapes are available because they had a tendency to strip off the gear teeth on the tape. These systems are the only ones I know that do not use the metal channel at the bottom of the window.
