Hood scoop?
Old Apr 30, 2013 | 11:45 AM
Sniper X's Avatar
Sniper X
Originally Posted by sls001
I purchased a hood from them and had no problems with them but that was 4-5 years ago. Recently I put a scoop on from Unlimited Products and they also make a quality product:
http://www.up22.com/scoopw1.htm#SC-1023
I put my scoop on mainly to get the heat out from under the hood and it has worked far better than my expectations. I've dropped nearly 20 degrees in engine temp when hot, idling in traffic and when going slow off-road.
Here is a link to some pic's I took while working on it.
http://s1034.photobucket.com/user/sl...w/Hood%20Scoop
As far as a snorkel; I have seen some done but they were all custom since no one makes a kit that is bolt on for our trucks.
Here is a link to one over on RCC:
http://ramchargercentral.com/technic...73/#msg1648773
Awesome truck! I hope mine looks that good when I paint it! I want a snorkel too, not as much for forging but they just look friggin COOL~!
Old Apr 30, 2013 | 11:52 AM
sls001's Avatar
sls001
Thank you.
At one time someone had done some research on the Safari Snorkels and found one that could be modified to work on a full-size Dodge Truck or RC but I didn't find it in my quick search. I'll have to see if I can find the link again.
Old Apr 30, 2013 | 12:01 PM
Sniper X's Avatar
Sniper X
Thank you.
Id love to see it because I have fabrication skills but won't do one from scratch. I would not mind to modify one for sure though!
Old Apr 30, 2013 | 12:03 PM
Sniper X's Avatar
Sniper X
On the OPS truck, I would do a Mopar snorkel like came on the Demons and TA's and such.
Old Apr 30, 2013 | 10:52 PM
Comrade General's Avatar
Comrade General
Nice truck. Changed your mind on which way you wanted it to face?
I like your custom gauge cluster. How was that? Whats that on the right side of the dashboard?
Old May 1, 2013 | 05:58 AM
sls001's Avatar
sls001
When I first got the scoop I played around with it facing forward in case I ever found a short-bed 2wd model to play with.
I wanted the scoop simply to get heat out from under the hood when going slow. But I can say that at highway speeds there is a very strong "pull" of air into the scoop. If I use my windshield washers above 50mph the fluid never hits the windshield it is sucked right into the engine bay
The gauge cluster was fairly easy once I had the basic shape cut out. I used one of the simulated wood grain decals as a template.
You asked what was on the right side - do you mean above the heater controls? That is the dual battery switch panel.
Thanks,
Old May 1, 2013 | 10:33 PM
Comrade General
Thanks,
No above the glove box
Old May 2, 2013 | 06:33 AM
sls001's Avatar
sls001
Oh, I made a plate to sit over the empty speaker hole, currently my GPS is there I might also mount a dock for my cell phone charger. I have a power port under it so can plug in accessories.
Old May 3, 2013 | 04:49 PM
Comrade General
ah cool. I dont have a speaker on the dash
Old May 3, 2013 | 04:52 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I think starting in the 90's they covered up the hole, and put the speakers in the doors.
