Replacement carburetor for my 79 W200
Old Apr 25, 2011 | 09:05 PM
wdriver's Avatar
wdriver
Question Replacement carburetor for my 79 W200
I need a replacement carburetor for my 79 W200, 360 V8, Carter Thermoquad. Must be California smog compliant. Carter TQ's seem to have dried up and are no longer available. Ideas?
Old Apr 25, 2011 | 10:19 PM
crazzywolfie's Avatar
crazzywolfie
can't you just get your current carb rebuilt? i don't know what is different between California smog compliant Carter Thermo quad and any other carb since if you have to do emission testing you could just lean the carb out to make it pass.
Old Apr 25, 2011 | 11:33 PM
wdriver's Avatar
wdriver
I've heard that certain parts for the TQ's are non existent and that rebuilding it may not be possible. ??
Old Apr 26, 2011 | 03:19 AM
RSDodgelover's Avatar
RSDodgelover
You might check your parts store, Edelbrock used to make a TQ copy that was great. I put one on an 86 d200 360 and it ran very well. Not sure about the Calif compliant though.
Old Apr 26, 2011 | 10:46 AM
Bobbyz's Avatar
Bobbyz
Thay still make kits for the TQ. As long as the throttle shafts aren't worn to bad and if nothings cracked should be ok.
Thay do make quadrajets new and I think thier a legal swap. But cost about $400. (You'd have to check for sure the Cali. thing.)
Old Apr 26, 2011 | 08:20 PM
wdriver's Avatar
wdriver
I called Edelbrock today and they said they don't have anything for my application. Fubar.
Old Apr 26, 2011 | 09:19 PM
charlie1935's Avatar
charlie1935
Holley made spread bore carbs for quadrajet and thermoquad replacement also.
