v6 5 speed on 318?
Old May 21, 2011 | 09:17 PM
fast_five_oh's Avatar
fast_five_oh
Default v6 5 speed on 318?
ok so i know of a dodge dakota with a 318 in it...but it has the v6 5 speed trans....its all bolted up an such...
will this work ok? if so i can get it to put behind my 86 d100
Old May 21, 2011 | 09:37 PM
crazzywolfie's Avatar
crazzywolfie
it might work. you would most likely have to measure the length of the transmission to see if it is the same. if it is the same i do not see why it would not work. otherwise you might have to find the correct length drive shaft or have a drive shaft cut and welded for your need.
Old May 22, 2011 | 12:46 PM
fast_five_oh
ok i did some more research an it should all work...but i do belive that dakota is a hydro clutch...
so here more questions...
will my crossmember work,will dakota clutch/brake pedals fit,and will a newer(98) 318 work in my truck...it will be converted to carb
Old May 22, 2011 | 02:27 PM
fast_five_oh
nvm my intake an header wont fir the new motor apparently....and the trans is about 6 inches short then my 727
Old May 22, 2011 | 02:51 PM
crazzywolfie
LA intake manifolds won't fit a magnum engine. you would have to get a new intake manifold to convert it to carb. you would also need a electric fuel pump and fuel pressure regulator.
