missing
so my 86 d100 (carbed) has had a miss since day one....not noiceable until at idle
has new dizzy,plugs wires, fuel pump etc...
whats the vacuum supposed to be on a 318 (have vac tester)
only thing i can think would be vac leak or carb issue
stock motor minus headers and chrome air cleaner
has stock 2 barrel
has stock 2 barrel
It sounds like a timing issue. It could be too far advanced, so when you're at idle with high vacuum it would be even more so.
Here's a long shot, but are you losing any brake fluid? Sometimes the master cyl can leak into the booster and the fluid gets sucked into the carb causing a miss.
