motor mounts
Old Jun 23, 2011 | 06:41 PM
aje1127's Avatar
aje1127
Default motor mounts
anyone know the easiest way to change motor mounts without a engine lift?? 93 d150 5.2. from under truck jack motor up by?? vib. damper??
crossmember to big to jack up by edge of oil pan on flange. any ideas?? thank you
Old Jun 23, 2011 | 07:48 PM
SixGun's Avatar
SixGun
It should be accessible with a bottle jack and a piece of 2X4 on the back edge of the oil pan rail. I put the 2x4 length wise on its side to spread the weight and to keep from crushing the pan or bolts. I unbolted both sides and loosened the trans mount to give it some play. I did one side at a time being careful not to jack it too high in the trans tunnel. It was real easy and quick.
Old Jun 23, 2011 | 08:34 PM
aje1127's Avatar
aje1127
hey sixgun, yea i figured a bottle jack,have 2 both need to be rebuilt. i guess it is easier to buy a small 2 ton,than to rebuild my 8 ton,or my 20 ton bottle jack. they just dont last to long setting in garage in the heat not being used. than you
