calipers?
Old Jul 24, 2011 | 02:03 PM
shortwide84's Avatar
shortwide84
Default calipers?
I am having trouble with my breaks. I don't want to say they are locking up because i am still able to move the truck but the caliper is deffinately griping the rotor causing it to shake and pull right pretty bad. When i bleed them out all is ok for a few days then the same thing. Is the problem the calipers, master, or something else?
Old Jul 24, 2011 | 04:29 PM
crazzywolfie's Avatar
crazzywolfie
have you tried pushing the piston in all the way on the caliper?
Old Jul 24, 2011 | 04:52 PM
Comrade General's Avatar
Comrade General
My dad 92 d150 went through several pairs of calipars.
Old Jul 24, 2011 | 07:45 PM
shortwide84
I haven't taken it apart yet because bleeding them is a quick temporary fix but i'm sick of climbing under there every few days. Calipers are 15 a piece so i hope that is the problem
Old Jul 25, 2011 | 07:32 AM
SEAL's Avatar
SEAL
I wouldn't wait. The calipers sound like they are just hanging up right now. If they freeze up they can generate enough heat to take out the rotors, bearing, hubs, and even the spindles. I would also change out the flexible hose any time you replace a caliper.
Old Jul 26, 2011 | 08:47 AM
wontacceptthis's Avatar
wontacceptthis
Make sure you have them on correctly too. A previous owner/mechanic didn't put the hold-down clips on one of mine. Occasionally the caliper would flip partway up and cause all kinds of trouble. It always slid back down when you stopped, so it took me a while to find the problem.
