1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
88 and newer is computer controlled throttle body injection. 87 and older is carbed but some of the carbed engines have computers behind the battery but you can convert it to a 4 pin ignition system for less than $300
88 is the first year comps were on all trucks so you're looking for 87 and older. If you do find a descent truck that has electronic spark advance (or lean burn), it is easy to remove the comp and go back to the ign module system. All you need is the plugs for the mod and ballast res from a non-comp system along with a vac adv distributor.
Good luck on the search!
