Coolant Sensor - how to troubleshoot....
Old Sep 28, 2011 | 08:10 PM
mjm1988's Avatar
mjm1988
Default Coolant Sensor - how to troubleshoot....
88 Dodge Ram w/ 318. Okay, so I pulled both valve covers (quite a pain, btw). Had to remove the brake booster on the drivers side, which meant that I also had to get under the dash and unbolt the booster. Anyway, after I got everything back together, now the coolant temp gauge inside the truck doesn't work. Any thoughts on how to troubleshoot would be welcome. thx, mike
Old Sep 28, 2011 | 08:26 PM
crazzywolfie's Avatar
crazzywolfie
sounds like you might have knocked the wire off the sensor. the coolant temp sensor should be located on the intake manifold right behind the alternator.
Old Sep 28, 2011 | 08:48 PM
89ram150's Avatar
89ram150
x2. It doesn't take much to knock it off.
Old Sep 29, 2011 | 04:05 PM
mjm1988's Avatar
mjm1988
Yep, that's what I thought, also, but the temp sensor is connected, no doubt about that...how about the connection to the gauge under the dash...is that just as easy to disconnect...and where would I find it....??? I am under the impression that the actual sensor connects directly to the computer, not to the gauge...also, when I connect/disconnect the sensor, I can hear the engine idle change, so pretty sure the connection at that point is okay. thx, mike
Old Sep 29, 2011 | 06:23 PM
crazzywolfie
sounds like you are looking at the wrong sending unit. there should be one on the drivers side of the intake that is for the computer and there should be another sending unit on the passenger side of the intake manifold for the gauge. to test the gauge you would just have to ground the single wire.
should look like this
Old Sep 30, 2011 | 02:04 PM
mjm1988's Avatar
mjm1988
Thank you, Thank you, Thank you!! I'll look for the sensor on the passenger side....sounds like the likely culprit!!! Will keep you posted. I hate these valve covers....PERIOD!!! About to go crazy w/ some form-a-gasket!!!
Old Oct 1, 2011 | 02:21 PM
mjm1988's Avatar
mjm1988
Thanks for a great answer - the picture of the sensor made it easy to find and, yes, it WAS disconnected...hooked it back up and..viola...got my temp gauge back!!!
