Help: Dumb Alt/wpump question!
Old Oct 17, 2011 | 05:48 PM
Alouie's Avatar
Alouie
That is the same thing I thought, but the battery slowly goes down when its off. I am going to top off the battery cell tonight and see what happens.
Old Oct 17, 2011 | 06:14 PM
sls001's Avatar
sls001
Then you have a draw on the battery...do you have any lights, accessories, radio's, etc left on?
Old Oct 17, 2011 | 06:40 PM
crazzywolfie's Avatar
crazzywolfie
i agree. there has to be something draining your battery after you shut your truck off. i would maybe look at that voltage regulator that is bolted to the alternator. it is wired straight to power. there is a reason it is hooked to ignition power from the factory.
Old Oct 17, 2011 | 06:50 PM
Alouie's Avatar
Alouie
I ended up buying a regular voltage reg and the pig tail and switching to that. I do not have any other wires going to the alt except the power wire, and that goes straight to the battery. Volt gauge has never worked since Ive owned it. I just went back out rechecked it, it seems to be holding at 12.30/31 while off. All of my accessories are off also.
Old Oct 17, 2011 | 08:43 PM
crazzywolfie
if you continue to have the battery drain you should hook the voltage regulator up to ignition power. it is not a voltage gauge in your truck. it is an amp which is kind of better.
Old Oct 18, 2011 | 06:36 AM
SEAL's Avatar
SEAL
Sounds like current is flowing when the key is off(a short). I would start by hooking up a meter or test light to monitor that current flow. Start pulling 1 fuse at a time until the draw on the battery stops. This will isolate what system is the problem. Some radios/stereos have a constant draw for the clock so the drop will have to be significant for that system.
mjm1988 just had the same problem.
https://dodgeforum.com/forum/1st-gen...-when-off.html
Here is how to check for shorts.
http://www.youtube.com/watch?v=pjXt7_gusgM
Old Oct 18, 2011 | 08:37 PM
Alouie's Avatar
Alouie
It is definitely a draw somewhere. There is fire when pulling the positive cable off and on the battery. The battery holds when the positive is off, and drains when on. Hopefully I will have time after work tomorrow to look, work is taking over right now. I did unplug the radio today and it still draws, and have the dome/cargo light bulbs out.
Ill start pulling the fuses tomorrow.. hopefuly. That way seems a lot easier then how I have been doing it.
