85 D350 to a W350
Old Nov 28, 2011 | 06:05 PM
bigtrucknut's Avatar
bigtrucknut
Default 85 D350 to a W350
Hi all, I have a 85 d350 that I want to turn into a 4x4. I am a half *** wrench and my wrench head says I need a 1 ton donor truck, SWAP EM OUT and im done. Have not done a swap before so what am I missing. thanks,BIGTRUCKNUT
Old Nov 28, 2011 | 06:11 PM
crazzywolfie's Avatar
crazzywolfie
Originally Posted by MYSTERYMAN
Converting a 4wd frame to a 2wd frame is a whole lot of work !!!!! You have
to change the front cross member and the engine cross member.. Weld in the motor mounts. Mount the upper control arm brackets.... None of the holes will be pre drilled for you. You will have to drill them all yourself.. The tolerance for these holes is .125 (1/8") on center .. If you miss the mark you may never get it to take a front end alignment or track properly...
I would not recommend doing a 4wd to 2wd frame conversion to a novice
or back yard mechanic..
