'91 D150 Injectors
I'm trying to find info on a set of injectors for my D150. It's got a 318 and until now has had the original or OEM replacement Bosch yellow top injectors. I've returned 3 different sets from 3 parts houses because they all run super rich. And I mean dumping fuel. Right now, I have BWD part #57222p injectors in it. And again, they run super rich. What am I missing??
I would look elsewhere also bit if you want quality injectors it is best to have them rebuilt and tested at a local injector shop. You only have to do that once to know they are not the problem. A TPS or an H2O sensor out of spec can also cause this.
I'll try to get the old ones rebuilt. The TPS and o2 are fine. I can swap back to the old injectors and the truck runs better, its just the old ones leak a little bit and the truck wont pass emissions.
