Clutch Linkage
Old Feb 10, 2012 | 12:52 PM
Superslow1069's Avatar
Superslow1069
Default Clutch Linkage
I did a engine uprgrade from a worn out slant 6 with a hole in a piston. To a fresh built 318, 40 over, nice comp cam and other nice goodies.
But my dumb butt during a the enging swap in the dark I dropt two little redish plastic bushings. Then moved the truck and ran them over (crush). There for the clutch linkage. They are for the pivoting shift rod where it meets from the transmission to the frame. The pivot rod had a ball on one end, the two part bushing cups onto the ball then slides into a spot in the frame.
Does anyone know what they are called or where I can get new?
Old Feb 10, 2012 | 01:35 PM
SEAL's Avatar
SEAL
Do they look like this?
http://www.autopartswarehouse.com/sk...g/RB14041.html
Old Feb 11, 2012 | 12:14 PM
Superslow1069
No, it about 1to 1.5 inches in length. Cylindrical in shape when two half are put together. It is split into two pieces length wise.
I am considering just getting a hydrolic clutch kit and fit it in.
