Main Seal Leaking?
Old Mar 15, 2012 | 02:41 PM
dairy's Avatar
dairy
Default Main Seal Leaking?
How do I determine for sure if its my main seal leaking on my 318. It drips a lot of oil after it warms up really good. When I look underneath it appears to be leaking from both rear corners of the oil pan. I have felt behind the valve covers and I dont think its coming from there.
Also do you have to remove the crank to replace the rear main on the 318.
Old Mar 15, 2012 | 02:50 PM
crazzywolfie's Avatar
crazzywolfie
you don't have to remove the crank. just need the right tools. i would say it is hard to tell if it is leaking. you should try washing your oil pan good to try locating the leak. i know i have tried locating a leak on the oil pan and it was almost impossible to find while it was on the truck. i took one off my 91 and got it brazed and more holes seemed to show up.
Old Mar 16, 2012 | 03:38 PM
dairy's Avatar
dairy
Is the only tool I need that is special is "No. KD-492". I belive you said that in a diffrent post.
Old Mar 16, 2012 | 04:13 PM
crazzywolfie
i believe that would be the tool.
