popping sounds?
Old Mar 29, 2012 | 06:49 PM
Craig_Martin's Avatar
Craig_Martin
Default popping sounds?
I have an edelbrock 4 barrel Carb on a 318, Dodge ram d100, and when I accelerate it makes popping sounds, and doesn't run so well, any ideas?
Old Mar 29, 2012 | 06:50 PM
Craig_Martin
Its a 1987
Old Mar 29, 2012 | 09:07 PM
SEAL's Avatar
SEAL
Check the ignition timing. How old are the plug wires, plugs, cap, and rotor?
Old Mar 30, 2012 | 12:11 AM
Craig_Martin
Was just timed, plug wires an plugs are good, Idk about the cap and rotor
Old Mar 30, 2012 | 06:17 AM
SEAL's Avatar
SEAL
A bad cap can cause this so it needs to be checked for carbon tracking or cracks. Moisture in the distributor is possible.
Old Mar 30, 2012 | 08:19 AM
wontacceptthis's Avatar
wontacceptthis
Check and see how clso together the plug wires are. I once had a nasty situation were i was getting heavy crossfire from poorly routed wires.
Old Mar 30, 2012 | 09:04 AM
SEAL's Avatar
SEAL
Wait for dark and start your truck. Look at the wires for arcing.
