90 B150 Transmission
Old May 9, 2012 | 08:26 AM
DrBob2's Avatar
DrBob2
Default 90 B150 Transmission
I have a 1990 B150 Van with only 71000 on it. I had a Cooling line blow on the interstate and it took out 3rd gear.
My question is, I have a 96 with a 32RH trans, Is there any way I can use the 32RH in place of the 999 trans that's in there? What would I have to do to the Electronics.
Thank You
Bob
Old May 9, 2012 | 09:32 AM
crazzywolfie's Avatar
crazzywolfie
i an pretty sure a 999 and 32rh are same. are you sure the 96 has a 32rh and not a 46rh or 42rh?
Old May 9, 2012 | 09:44 AM
DrBob2's Avatar
DrBob2
Yes it's a 3 speed./ Factory service manual says 32RH. I know I have to change the shift linkage but am wondering about the electronics.
Old May 9, 2012 | 10:06 AM
crazzywolfie
if the 96 does have a a 32 rh then it should not have any electronics that the 90 does not.
