Message center lights going off
Old May 19, 2012 | 02:49 PM
dirtracer39's Avatar
dirtracer39
Default Message center lights going off
I got a 1990 dodge ram, for the past month my maintenance required light has been on but before I don't it put from winter storage I serviced the truck so I ignored it, then I did a burn out the other day and my parking brake and anti lock brake lights are on now too, I checked all the connections and everything looks gone behind the dash.... And to boot my odometer stopped working .... Any ideas?
Old May 19, 2012 | 02:51 PM
dirtracer39
First part does make any sense, damn autocorrect
Old May 19, 2012 | 09:53 PM
wontacceptthis's Avatar
wontacceptthis
Did you happen to do a brake stand? You could have burst an old hose or line if you were standing on the brakes. Also, try unplugging the your ABS module. Its behind your glovebox. Always make sure to check your brake fluid as well.
