correct tire psi 1990 RC?
Old Jun 28, 2012 | 10:20 AM
kuziwk91's Avatar
kuziwk91
Default correct tire psi 1990 RC?
I have a 1990 dodge ramcharger 5.9L. I have falken 275/r17/55 tires and rims from a newer dodge. I lost the inside door sticker im just wondering what the correct tire psi would be as per spec on the door sticker. I think im at 35 psi right now. Also what rear end ratio might i have thought it was 2.76 but i heard the RC only offered in 3.23?
Old Jun 28, 2012 | 10:26 AM
crazzywolfie's Avatar
crazzywolfie
you should read the side of the tire. it will tell you how much air you should put in your tires .
Old Jun 28, 2012 | 11:14 AM
kuziwk91's Avatar
kuziwk91
It just says Max psi of 50
Old Jun 28, 2012 | 12:06 PM
sls001's Avatar
sls001
Gear ratio is either 3.23 or 3.55
as for your tire pressure it should have a suggested tire pressure on it...not the max psi. Check the manufacuturers website for your tire model.
Old Jun 28, 2012 | 04:39 PM
Trialbyfire's Avatar
Trialbyfire
I run all of our tires so that there is just a slight bulge so that they wear relatively even, and tend to prefer to keep them on the stiff side for better fuel mileage. My truck tires have a max of 42psi, I keep them at 38psi unless pulling an x-heavy load.
Old Jun 28, 2012 | 07:21 PM
dlyter09's Avatar
dlyter09
If the max is 50 id run them between 42-44
