89 360 tbi to carb need some help
Old Aug 5, 2012 | 04:33 PM
wyododgeboy's Avatar
wyododgeboy
Default 89 360 tbi to carb need some help
ok i have a 89 w150 360 in it i want to convert it to carb
i know i need a intake a carb fuel pump new distributor
my question is my stock distributor has the electronic advance wire on it
do i need to keep the electronic and is it even possible to and if i go to vaccum advance how do i do it and were would i hook up the vacum lines
just not to sure how it all works .
if anybody can tell me how to do the conversion or were i can look to find out how i would really appricatie it
Old Aug 5, 2012 | 05:15 PM
sls001's Avatar
sls001
A. Why would you want to do it?
There are other considerations as well...you charging system will need to have a voltage regulator wired in. If you have AC it will need some re-wiring and if you have OD you will need to do some re-wiring on that as well.
